Well all, I have around 180 miles on my motor now and my e4od seems to be running hotter than it did before the motor melt down. I'm up around 200 degrees all the time. I have a Banks electrical gage on the trans. My point and shoot thermoter says its around 150 degrees when my gage says its 200 degrees. Today I got on the freewayand was not in overdrive till I pushed the switch. It wouldn't go in no mater what I did. I got home and checked the tps and it was still at 1.02 volts. I tested it against my new batteries and they both showed 16.42 volts..... I tried this test on my other truck and it was just a bit lower but still higher than 12.5 volts. The motors were not running either. So I went out an bought another digital multi meter. My 2 truck batteries showed 12.42 volts... I checked my tps setting and it was .77 volts at idle....
I have a really bad feeling I ruined my trans because my voltage to it from the tps was too low for a decent torque converter lockup. I reset it to 1.01 volts at idle and had 4.85 at wot. The test run was hotter than I thought it should have been, back up to 200 degrees around town. Still the piont and shoot said it was 155 degrees. I know the piont and shoot is correct because its used to check the thermostats in the boiled water on the stove. I sure hope Brian at BTS can ship me a trans because I can't risk driving to him like I planned to do. DAMN DAMN DAMN....
