derjackistweg
Hi,
I got an 92 E350 Quigley with an 7.3 IDI and an E4OD connected with 100t miles.
At some point the OD light appeared (no loads, no pulling just driving inside the city). 50 miles later diff gave up so I could not test anything but it seems that OD was not engaging anymore.
While in the shop getting a new diff, it appeared that the alternator burned up and killed (as it seams) the batteries. After installing a new alternator the E4OD Transmission only shifted into 1 gear.
The van was jump started and with the tranny in D, it stayed in first gear. Shifting manually through 1/2/D did not change anything. Driving in D did not shift, either under load or not. It still shifts into rear though.
Tranny oil is at optimum level.
Tranny oil is read and does not smell burned.
Filter is not checked so far, nor the oil pan.
What is to check before buying a new one? E4ODs are electronically controlled as I heard. What can be checked with having to many labor costs?
I need to pull the connector from the IP. I guess that these problem come together in any burned something (fuse, relay .. I have no idea)?
