Dynomax 19430 Exhaust System
FoolhardyIDI
Arizona
New exhaust
FoolhardyIDI
Arizona
Now I have never posted a video to the forum. I'm not sure how to do it. Could someone explain to me how to upload the vide of how the exhaust sounds? Thank you
chillman88
Central NY
I'm not sure. Honestly I usually just upload them to youtube and paste the link here.
I like the sound. A nice, deep rumble at idle, not much louder at a little bit higher RPM's. How does it sound when you're on it hard?
FoolhardyIDI
Arizona
When I get on it, it sounds like the Flowmaster exhaust on my old K2500 454 Suburban. Man it is sweet.
Eli
Texas
Did you modify the hangers, or did Dynomax fix their low-hang issue?
Kind of surprised the cold idle solenoid didn't kick in in the video.
Eli
FoolhardyIDI
Arizona
Eli
I modified every single hanger. To work with the welding of the system and with how I wanted it to sit under the truck.
FoolhardyIDI
Arizona
Eli
Also here in AZ no need for a cold idle solenoid. So I disconnected that a long time ago.
FoolhardyIDI
Arizona
So my EGT's have dropped by 150 degrees since the exhaust which is great news. So I did a slight mod to the air cleaner. I cut off the neck on the air cleaner housing and opened it up to a total of 8 inches across by 2 3/4 inch high. Took the truck out for a drive again to see if this helped any or hurt any. To my surprise, it took an additional 50 degrees off my EGT's.
zemmeron
