Driveline Park Brake
Kevin 007
Full-floater
Nelson BC Canada
Anyone on here have any experience mounting/fabbing/custom installing a driveshaft parking brake on superduty F450/F550 4x4 applications? Dana 135 diffs in my case.
The factory hub style park brakes are a joke and i'd like to upgrade to something much more robust and trust worthy.
Any thoughts? I recognize it will be a custom job and will be pricey, but im ok with that. I do run hydraulic line locks and they help for sure, but are not considered a mechanical hold option for a legal park brake
u2slow
bilge rat
Coastal BC
The factory hub style brakes make your truck legal.
Add-on hydraulic line locks are a typical add-on for any tow-truck operator.
Edit: there are aftermarket parking brake add-ons for np205 transfer cases.
Dirtleg
Cloverdale VA
I am looking at this issue right now. I happen to have a pair of 2007 Mustang GT rear calipers sitting around and the rear discs as well. They have a cable operated parking brakes.
I think with some planning and fabrication a driveshaft could be modified to hold the disc and a bracket mounted to the frame to hold the calipers. Both calipers could be used on a single disc. Could also try and get a flange made to mount to the transfer case.
I haven't dug too deep yet. Currently just toying with the idea.
Rayfish
