biggin92
Yeeeee Haaawwww
Hello all . Haven't posted in a while. I've been working on my 94 f350 cummins swap. I wound up using the dodge trans and newer dodge transfer case with a 99 sd driveshaft. The problem I'm having is the rear section of the shaft seems like it keeps grabbing the front section and trying to pull the rubber out of the back of the carrier bearing. The splines look good and the blue coating is still in good shape but it doesn't move easily. What do i need to try?
