DOH, Sterling 10.25 axle vent snapped off
runaway!
Wisconsin
Finishing up the overhaul on the entire brake system, I was removing the rear hydraulic brake line and twisted off the axle vent bolt that also holds the line on the axle.
I'd go to a yard, but I'm in the rust belt. It will be a lesson in frustration, I'd bet many will snap before I get one worth using.
Still ended up being a happy accident, found out the tube was severely clogged.
Is there a part number for that particular part or a good way to redneck engineer something that will work in both capacities?
Dieselcrawler
Professional wrench holder
Quakertown Pa
any ford truck or bronco axle uses that fitting. use an easy out to remove the broken one. it is pipe thread IIRC.
Hardass559
89 7.3 banks turbo
falconer/new york/usa
i live in the rust belt as well western new york but i have never broke one i find ther a safer bet to pull and put in gear oil than the fill pug so i have taken out alot of them just use a impact wrench the first time they come right out
RLDSL
Diesel fuel abuser
Arkansas
Soak the stuck fitting with aero Kroil for a few days before attempting removal so you dont end up with a broken easy out in there. Bring the kroil to the boneyard and hit the one you want to remove and then go get a sandwich to give it time to soak in before trying to pop it out.
sassyrel
iowa
and dont EVEN think about buying that breather bolt form ford!!!! less you want to rob a bank first!! that fitting,,has straight threads into the axle housing..they arent tapered like pipe...
Sounds like a big event is at hand here. Finding one in a wrecking yard will be easy. Getting one off a wrecking yard Ford or mer or other big ford rig is going to be fun. But thats park of the yard search fun.
GaryB
