Finishing up the overhaul on the entire brake system, I was removing the rear hydraulic brake line and twisted off the axle vent bolt that also holds the line on the axle.
I'd go to a yard, but I'm in the rust belt. It will be a lesson in frustration, I'd bet many will snap before I get one worth using.
Still ended up being a happy accident, found out the tube was severely clogged.
Is there a part number for that particular part or a good way to redneck engineer something that will work in both capacities?
