ttman4
Last Nite's Dream..
- Joined
- Oct 31, 2005
- Posts
- 1,096
- Reaction score
- 614
I'm digging up & compiling info. to do my DMF to SF conversion & have looked & saved all the tec articles I can find.....and as usual I remember some from the past that I can't find now, or have forgot where I put them.
I would estimate mine (FW, clutch, P/plate)has approx ???K miles on it...I don't know, but a lot! & it's been bigtime HOT twice in years past. So hot once the whole road filled with smoke but I had to get'er outa the road. Let it sit overnite & she been running A-OK ever since, till lately. Been playing with my IP again, finished my "RamAir", & couple other "upgrades." Then she slipped yesterday "blowing the smoke out" in 5th gear, but I couldn't make it happen again after that in any gear.
But some questions: '90 CCD 2WD
1. I think I have a 11" clutch...after converting & going to a spring loaded clutch kit, does anybody know if my DMF will/can use a larger clutch & pressure plate, or only can go back with same size setup? Or is more machine work required?
2. I've seen some talk about checking/testing the DMF for wearout & play (1/2"-to3/4"max). I didn't understand if this can be checked still mounted in truck, or only after removal of tranny etc?
3. About 350K miles ago I had the engine out & had the flywheel resurfaced. I don't remember how much was milled off & I don't remember how thick the original flywheel specs call for, but will find it later....unless somebody here knows. I've been told that if a flywheel is resurfaced, there needs to be an equal thickness spacer/shim put between FW & crank to bring back out to original distance.
Last question:
4. Should I just buy several lottery tickets & go buy a new truck, or keep working on this'n? I like working on this one because all my friends, pals, & buddys keep telling me these projects "can't be done!!!"
Besides that, evertime I buy something new I gotta carry it home & start tearing & fixing it to suit me anyway!!
Last question:
