Do not know how to post pic will try . My OC 20 runs on 55 gal drum
recirculating constantly measured time takes 1hr 15 min to pump 55 gal
threw oc 20.
1- OC20
1- OC20 pump
1-55 gal drum plastic
2- 3/8 barbs one in bottom one in top
1- 1 1/4 x 6 inch pipe niple scewed into OC 20 bottom
1- 4 inch pvc coupling
1- pvc air hose cut and use for plumbing
Set up OC 20 per instuctions, take one bunge out. Set 4 inch pvc coup
over hole ,then OC 20 with 6 inch nipple on top of pvc coup this makes outlet of OC 20 about 1 to 2 inches inside turn on pump and let run.
Ran oil threw 50 feet 3/8 copper inside turkey fryer pot filled with water with 120 v bucket heater inside if water boils out heater is self regulated so very safe and can run unatended safely. And did add air hose quik conects to OC 20. Outlet of OC 20 must
be above oil any backpresure will not let it spin properly. This
also removes moisture. When I am sure oil is clean as pos I
then use OC 20 to transfer oil to a 55 gal mix tank cycling
all oil threw OC 20. Mix 50 % diesel then filter with fuel fill set up
from tractor supply 10 micron then 2 micron fuel filters.The
kind for fuel delivery pumps.Also any magnets I can find go
on bottom of fuel filters.
