87-F-250
Well just about got the centrifuge installed. See link
I just need to tap into a wire that's hot only when the engine is running.
I put a wire on the oil pressure sender and tested it with my test light. It didn't glow much so it just must be a signal to the gauge.
Maybe I could use the signal to trip a relay?
Any good places for easy access to 12volts when the engine is running?
I could use a regulated one way boost line for air instead of military and space designed pump.
