Diego Revisited
chillman88
Central NY
I wasn't planning on a build thread for this truck, but working on it today I realized how much I've already done to it, and that there's still a bunch left to do so here it is!
Late last year I picked up a 1990 F250 from @saburai. He retired it from hauling his live-in bumper pull camper.
I drove it around 3hrs home and started tinkering with it. Swapped out the steering column with one that didn't wobble all over, put a working radio in, put a Lund visor on, and swapped the grille guard from my Dually.
The tires on it were great highway tires, they SUCKED in the snow. I had some old tires on a parts truck, swapped them on...
Drove it for a month or two and had an unfortunate incident where the radiator froze up and cracked the radiator. Turns out it was weeping from a couple other spots anyway. I bought a new radiator for my dually and put the old brass radiator in this truck, and added a large auxiliary transmission cooler.
chillman88
Central NY
Last week I filled the cooling system up with Rotella Nitrate Free ELC and I tossed on a grille blanket/screen set.
Today I finally replaced the crappy wiper motor with a used one I had here. I was going to replace the wiper arms, but the used ones I have are a little loose, the ones on the truck are still nice and tight!
hacked89
Bucks County PA
What new radiator did you go with on the dually and how do you like it? My radiator broke when I pulled my truck apart. It barely tapped the fans and a blade went through it. It was a new radiator from the PO, but the metal was very fragile.
Sent from my SM-G955U using Tapatalk
chillman88
Central NY
I bought a Mishimoto radiator. Not overly pleased with the quality, but I was hoping spending just a little more would get me better quality than the cheap ones. Time will tell.
https://www.oilburners.net/threads/tank-my-91-crew-cab-dually.84233/page-16#post-1053623
chillman88
Central NY
Well I put the new registration sticker in the window today and cleaned out the truck a little bit.
This truck has had an odd rattle when I close the door since I got it. I pulled the drivers door panel off and reached inside the door, pulled out a bolt about 1“ long about 1/2" in diameter. No clue what that came from?? Put some new Christmas tree clips on it and now the door panel doesn't rattle either! Score x2!
saburai
And you got a free mystery bolt:Thumbs Up
Selahdoor
Index Wa
Christmas tree clips?
Yesterday, I applied the new tabs to the plate. I have officially had this truck two years!! Man, time went fast.
Today, I have been working between raindrops. Taking my time. Paying close attention to each step.
was figuring out whether the rear door was worth fixing or not. Could have decided the canopy wasn't worth it, if I couldn't fix the door. Not going to spend 600 dollars on a special order door, for a free canopy. LOL
It's worth it. I got it pinned back together and fixed a couple bends... It's going to work just fine.
Tomorrow I'm hoping it doesn't rain like it did today. I want to get the plexiglass cut to shape and size, and put into that door frame.
Then I'll move on to fixing the front window of the canopy. Thinking I may just take out the other sliding pane.... And make one solid piece for that area, out of plexiglass.
One thing has me concerned. I'll have to remove the canopy, to finish the work on it. Still haven't figured out how I am going to do that by myself.
Maybe for the front window, I'll just get up underneath it, stand up, and spin it 90 degrees. If I even can. I'm not as young as I used to be.
But I have to get it completely off of there anyway, because I have to repair damage that has been done to the bed of the truck.
So, we'll see,
Edit: Whoops thought I was in a different thread. LOL
Didn't mean to hijack your thread Chillman!
chillman88
Central NY
Be careful. Those things are heavy! My aluminum one is plenty heavy, those fiberglass ones are even heavier. I'd offer to help, but it's a little out of the way LOL
Selahdoor
Index Wa
Ah! Thank you! It's obvious why they are called christmas tree clips! :D
chillman88
Central NY
From another thread... https://www.oilburners.net/threads/...-your-truck-today.60076/page-323#post-1054346
I think I shook that magic 8 ball just right to squeeze another drop of luck out....
I don't dare more than look at it, but it looks like it's in there. I can't find my JB weld or I'd slather it. We'll see how it goes, fingers crossed.
It's actually a transmission cooler fitting from the old aluminum radiator. I was able to swage the hole ever so slightly with a tapered punch, then start an 1/8npt tap in the hole. Just BARELY started it and snugged the fitting down.
Fill the radiator to the top. Then use a propane torch, and silver plumbing solder on that.
Were you close enough, I'd do it for you.
Pretty sure I am going to have to solder it. It seems to be leaking pretty decent from those threads (as I feared).
Other than that and another spot that might be seeping, it seems to be holding good. Hasn't overheated at all.
Checked the transmission fluid today, these dipsticks SUCK to try and read! Looks low so I'm going to pick up a quart tomorrow. I expect that though from losing whatever was in the old radiator and adding the new cooler too.
