Did all Crew Cabs have locking rear diffs?
SLC97SR5
UT
My CC is open.
Do not confuse a factory limited slip with a locker.
6 Nebraska IDIs
Yes yes, I know the difference between limited slip and locking diffs. Locking diffs are mainly an aftermarket item, the locker in my brown trucks rear end is an EATON unit IIRC, I'm not sure who makes the ford limited slip units.
I don't know of any limited slip diffs that click the way a real locking diff does.
All of my old camaros have eaton locking diffs from the factory GM plant, my brothers shelby mustang has a ford limited slip, and his new 68 GT sprint convertible has a limited slip as well.
troupp
Roaring Branch, pa
mine came with a one wheel hopper, but after having some bearing problems.. It was switched over to a factory limited slip... with lots of slip might I add.
After exhaustive research all rear's where limited slip on automatics, only special order would you get one or change it yourself to a locker.
u2slow
bilge rat
Coastal BC
I have a dim view of factory traction aids... the 'slip' is in NO way limited. It actually runs away once it begins. "Limited slip" is a misnomer... it implies it should slip a certain amount, then stop. Quite the opposite of what it does.
IMO.... :sly
Open diff = "No traction differential"
Stock LSD = "Limited traction differential"
85hauler
Reno
The '89 Dually I sold my sister is open. My other 3 crewcabs (2 SRW and 1 Dually) are Limited Slip.
I've also had 2 460 powered Crew Cab Duallys and they were both limited slip.
12 2.73 3800 FORD REG 1991
17 3.25 3300 FORD REG 1971
17 3.31 3800 FORD REG 1995
18 3.08 3800 FORD REG 1991
19 3.55 3800 FORD REG 1991
25 4.10. 5300 FORD REG 1991
29 3.55 5300 FORD REG 1991
35 4.10. 6250 FORD REG 1991
36 3.73 7400 DANA REG 1980
39 3.55 6250 FORD REG 1991
45 4.10. 7400 FORD REG 1991
49 3.55 7400 FORD REG 1991
65 4.10. 8250 FORD REG 1991
69 3.55 8250 FORD REG 1991
72 4.63 11000 DANA REG 1991
73 5.13 11000 DANA REG 1991
H5 4.10. 3800 FORD LIMITED SLIP 1991
H7 3.31 3800 FORD LIMITED SLIP 1995
H8 3.08 3800 FORD LIMITED SLIP 1991
H9 3.55 3800 FORD LIMITED SLIP 1991
B5 4.10. 5300 FORD LIMITED SLIP 1991
B9 3.55 5300 FORD LIMITED SLIP 1991
C5 4.10. 6250 FORD LIMITED SLIP 1991
C9 3.55 6250 FORD LIMITED SLIP 1987
D5 4.10. 7400 FORD LIMITED SLIP 1991
F5 4.10. 8250 FORD LIMITED SLIP 1991
W5 4.10 8250 FORD LIMITED SLIP 1995
truckonfire
