Dana 60 Steering Bumpstop Adjustment
jhenegh
Truck Still Earns its Keep
Deerfield, WI
Is there any procedure for adjusting the bumpstops on the Dana 60 knuckles? Mine looks like I could get it to turn sharper, but I don't want to turn too sharp and bind anything.
I do need to confirm that I have the same number of turns from side to side once I get my new steering box in.
F350camper
BOOST!
when I had my 92 f350, I took the steering stops out, and put them in the glove box...
F350camper
BOOST!
All I can tell ya is, I didn't have any ill effects. It was a 92 crew cab, it had the turning radius of the titanic before and after removing the steering stops, but it did make it a little better. Since I was able to remove mine, I'm sure you are safe to adjust yours however you would like.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Did you have any problems with the axle U-joints binding up with the wheel cranked hard over while the front hubs were locked?
That's the only potential problem I can think of...otherwise, sounds like a great idea to me! ;Sweet
sjwelds
Central KS
Hmmm. I have slightly oversize tires (285/75/16) and until I installed some 1/2" wheel spacers the tires would sometimes rub on the leaf spring. Not sure I'd want to remove the stops....
truckonfire
