D60 driveshaft?
NJGearhead666
New Jersey
Ok tonight i picked up a D60 out of a 95 F350 with springs and everything. Now some people including the guy i bought the D60 from says i can use my 250 driveshaft. some don't. What is the difference between the 250 and 350 driveshaft?
mobilemech
Redding CA.
the f350 driveline has a cardigan or CV joint on one end. the f250 shaft will work if you have a d50 TTB in the truck you are swapping the D60 into
junk
Paullina, IA
When I did my dana 60 conversion I used an F250 driveshaft with normal U-joints. Never noticed any problems with it. I also went from 2x4 so I ended up making a crossmember and stuff.
subway
be nice to the admin :D
York PA
i hope you got the panhard bar and brackets, they can be hard to locate. Jason, freebird was working on replacements
Take lots of pics and make it into a write-up. It would be a nice add to our technical library.
NJGearhead666
New Jersey
Already started checking it out and making my parts list. Just got done sandblasting the panhard bar and bar bracket
