It seems that at some point in time, Ford called for the use of Dexron fluid, at least in the C6. On my truck the dipstick says you had to use Dexron II in order to not void the warranty. Of course nowadays, Ford says that Mercon V replaces all the previous fluids, but I was always under the impression that Dexron was a GM trademark. I realize that Dexron and Mercron are essentially the same thing, but if so, why would Ford have specified a 'rival' fluid???
