rvassar
I've had some problems with my wife's 7.3l Excursion. I've had two incidents where I was running in cruse and had to hit the brakes, and found myself fighting to throttle. The first time was last fall, person in front of me decided to make a surprise unsignaled right turn and I had to get her stopped... I'm pretty sure I thumbed the off button, but things were getting just a bit exciting, as I had to start correcting for the torque induced frame flex... I ended up cutting the ignition.
Last saturday it happened again. This time I had more time. I had the brake applied, and the engine started to spool up. I hit the off button and held it, no change. I then started hunting around the off switch, trying to rock it from left to right, trying to find a good contact patch. At the same time, I pressed "coast". This seemed to do the trick, and she dropped the throttle.
I took it to the dealer yesterday, and had them try and diagnose it. They were unable to reproduce the problem. They even admitted they drove it all the way over to Taylor for lunch trying to reproduce it. (and didn't even save me any BBQ!) They don't see any point in throwing parts at it, so it's back in the driveway.
I'm at a loss. It seems to be a triple failure. The brake light switch, the hydraulic backup, and the steering wheel switch. There's no servo to stick. All of this points at the PCM.
Anyone have any ideas?
