BlueBreadTruck
IDI
If you take it to a competent welding shop, they should be able to weld the crack, no problem. You will have to drain the coolant, and they would have to do a good pre/post heat so it does not crack, but not very hard at all
I can't afford the time to strip it down and take it to a shop. I think the cost would outweigh the value of the truck anyway. I'll keep a close eye on it and when it starts loosing coolant I will decide.If you take it to a competent welding shop, they should be able to weld the crack, no problem. You will have to drain the coolant, and they would have to do a good pre/post heat so it does not crack, but not very hard at all
Wow...I have NEVER seen anything like that locknstitch...
Man, makes you sure wonder when these days a crack like that would just be an instant boat anchor with no questions asked.
