CPS question
69oiler
I don't feel tardy
Chardon OH
ok so today i got a check engine light, and reduced power. the trucks starts normally. the CEL seems boost related, because i can make it go on and off by making boost (on with boost, goes off at idle or cruising)
one weird thing, even though the truck starts normally, the tach does not move for the 1-2 seconds during cranking. do you think it's a CPS issue? none of the other symptoms seem to fit CPS problems that i know of.
i have an appt at the dealer tomorrow to get it scanned.
97idi
mt airy/maryland
from my experiecnces with any truck and the cps it seems to have trouble starting and it idles rough
howards@howard
Byfield MA
cps
I had one in a 98 that was intermittent ran off and on for weeks. Get the IH one on line and put it in yourself
93turbo_animal
Marengo,Ohio
Most CPS victims complain of cutting out not reduced power. I would look at either the IPR ICP or the MAP sensor
69oiler
I don't feel tardy
Chardon OH
it turned out to be a P0476 exhaust backpressure control valve code
in other words the wastegate was sticking. the problem went away overnight, but now i know where to look if it happens again.
i got my trans flushed while i was there too.
Russ
Idont do injectors
New Brighton PA
It's not a wastegate Rob, It's the EBPV. A wastegate dumps extra boost to the atmosphere.
69oiler
I don't feel tardy
Chardon OH
yeah my EBPV has been unplugged for a couple years and i told the tech that. he said it was the wastegate sensor or something to that effect. which would make sense, since the turbo noise changed and the CEL only came on under boost, and went off at idle or cruise.
i think the waste gate was hung open, that's the way it was acting. EBPV can't move with no power to it
Double-S-Diesel
parts seller
derry pa
the 476 has to do with the ebv bieng unplugged and nothing else.
I would swap the cps if there were no codes.
69oiler
I don't feel tardy
Chardon OH
then why did i lose power? and why did it wait 2 years to throw a code? as you know, my EBPV is unplugged since we did the 4" exhaust, so it couldnt have been closed. there was a distinct loss of power as well as a change in the whistle of the turbo. the exhaust note from inside the cab didn't change noticably though.
i guess it doesn't matter as long as the problem went away. i just like to understand WTH is going on.
i just put a CPS in it... well, the time you came to the rescue at that hunting camp, and the tech confirmed it was the "updated" part. i do have a couple spares around though
he also did the cruise control band-aid while it was there.
69oiler
I don't feel tardy
Chardon OH
i see there's a P1690 wastegate control valve malfunction on the list above, too. ok i guess i should just ride it out and save up for my V10
93turbo_animal
Marengo,Ohio
:puke::puke: The EBPV being unhooked does not throw the CEL but it does store a code in the computer. If you were losing power from defueling the sound of the turbo would change as the drive preasure would be decreased. I still think your problem lies else where
Double-S-Diesel
parts seller
derry pa
all my trucks have the 476 code including my old 96, it will not cause a ses light or loss of power.
should have been more codes, need a better ford tech.
havent ever seen a wastegate code on a normal truck, I have lots of them but that because the wastegate is no hooked up.
Interesting thread. Does anyone have a diagram or pictures of where these two sensors being discussed are? It kills me that most thread in seem to involve going to the dealer at some point.. including my own. WE ARE BETTER THAN THAT. There has to be a way! But I think the lack of education in threads like this one have a lot to do with that. Now, I know I have a working EBPV, and I'll be honest... I like it. It DOES warm the truck up faster. I can also tell by the sound when it is working. Rob's description of his problem seems to match what the tech reported. But like he said, if the wastegate sticks open again, how do we troubleshoot that? A lot of us are happy with just 250HP. LOL Transmissions and firmware are another matter. :backoff
:D
