Cow Catcher
BR3
Mt.juliet , TN
Done lots of cluster work. Have large portions of an idi cluster in one of my psd trucks right now.
What's wrong with yours? Parts of them are interchangeable, other parts aren't. The speedometers are universal so far as my experience, if what I've found holds true, they all had the capability to run the auto (the speedo, or psom as some call it, does in fact send speed signal to the e4od) some just didn't use it. From 4.9 gasser all the way up to 7.3 psd best I can tell. The rest is engine specific, with some overlap, as well as year specific, with some overlap. All the diesel side gauges I've played with had the same steppers, but some seem to work slightly different. Gassers used different steppers with add on resistors. It is super easy to swap out portions if you already have it out anyway. And I'd be wary of unknown parts. The psoms are getting old and "shaky" these days, and the autos rely on clean signal to determine shift points, so a shaky speedo could cause erratic downshifting.
Several companies offer "rebuild" services relatively cheaply if it's something like that
BR3
Mt.juliet , TN
Also the psd won't turn on the alternator withought a psd tach or some custom work, I don't think the idi cares either way, but I've never tested that one
79GLIDE
Omaha
Speedometer was bouncing, but won't move now. Odometer displays mileage when speedometer stopped working. ABS light on. You know the drill. Everything else functions properly, except transmission shifting, which I manage with the selector and OD button. I replaced the sender with an OEM part. No improvement. I'll pull the speedometer off the '94 cluster and try it in the '93. I really appreciate the info.
BR3
Mt.juliet , TN
Well it still could be the vss as well in fairness then. If that does turn out to be all that's wrong I'd call a psom rebuilder, that way you'd know what your getting and it's really quite reasonable
Big Bear
