biodiesel_wv
Hey there,
I read a few threads here and I didn't see one like this so I figured I'd ask or call Click and Clack so they can laugh and me. I'll give you all the first laugh. I have a 1990 F-250 truck with the 7.3 Diesel International engine. The radiator went out, anti freeze everywhere. So, I went to the junk yard and got one. I swapped them in the Walmart parking lot with out making too much of a mess, but on the way home it over heated. Filled it up to try again and no luck, but there's stuff floating in it. I pulled the radiator and sure enough at least two mouse nests were in it (one on top and one in the bottom). I was a little stressed out when I put this radiator in, so I didn't pay too much attention just got it done.
I went back to the junk yard and got another radiator, this time I flushed it with a garden hose before I put it in my truck. Only a few acorns rolled out so I figured if it wasn't good at least it was better. But the truck still over heats. I think some of the shredded up shop rags from the first radiator and mouse nests must have gotten sucked up in to the cooling system.
My questions are:
What do you recommend I do?
Where is everything stuck?
Do you have to take off the alternator to get to the thermostat?
Would it even help to do a cooling system flush or should I use Drain-O, tough on hair and clogs?
This second radiator didn't have a port for the small coolant line that is T'd in to the line from the engine to the heater core, so I just plugged it, is this a big problem?
Is there any hope for me?
Thanks for your help,
Matt
My questions are:
Matt
