dieselrulz
I've read, and read, and read... so I have some background, but a couple questions.
For starters, 1989, F250, 7.3, zf5. 196k. It got to where i was cycling the plugs 3-4 times when it was 40ish degrees to start it, so I decided to replace the g.plugs. (i've replaced the controller and relay previously, when the issue was actually a melted harness... but i digress.) Since I was in there, I have been curious about the compression, and thus decided to test it. (with the truck off, parked on a steep hill, in 1st gear, it will slowly creep forward.) I also replaced the factory starter with a powermaster 9050, based on a handful of threads i've read here, and replaced the alternator because it was only charging when the rpms were over 1k. The truck sat for about a week while the parts were shipped in. That was when i did the test, which leads to question 1:
With the truck sitting for a week, cold, would compression expectation change? Should I retest warm/lubricated? I also only tested cyl 2, 6, 8, and 1, 5, 7. I couldn't get the tester threaded in and connected to #4, or #3 without removing the hard fuel lines, and i figure 6 numbers would give me a good feel, since there isn't any real issue how the truck runs. the numbers i got were 345, 345, 410, 390, 350, 390. (not sure if it matters, but those are listed in the same order as listed above.) I am of the impression that 400+ is considered "good," while 350 is considered "minimum?" (with 20% variation max)
the follow up question is, what do those compression numbers mean to me? I have owned the truck 11 years, and have noticed the power drop while towing, but it still gets the job done. I love the truck, and i'm not opposed to rebuild, but i also work for every dollar, so it won't be an easy choice...
newly registered, long time lurker. =P
