cold start high idle switch
bubbahzanetti
I have a 88 7.3, non turbo... does anybody know where the temp switch is that controls the high idle and timing advance? I have no power to that circuit on cold starts. Thanks!
BZ:dunno
Al_E
Waupun WI
in the head rite behind the thermostat housing (upper radiator hose)
bubbahzanetti
The mystery solved!
Gracias, I'll look there in the morning, but I don't remember seeing any type of sensor there, I'll have to look closer. Screw in brass sort of thing with wires, is it?:confused:
suv7734
BC Canada
Screw in brass sorta thing with '2 tabs' on top of it. One is +12volts in, the other +12 volts out. Can't remember the temp for cutout right now.
85IDI
can a switch be wired in to have manual control of it
f-two-fiddy
Duluth, Mn.
Run a jumper wire from the + battery to the High Idle Solinoid. It'll tell ya right away if the soliniod is operational.
dave186
Idaho
the sensor on mine didnt work and it was like $50 at the ford dealer so i wired a switch on the dash for it. the temp switch simply completes the circuit when its cold.
mitsu tractor
