clutch pedal part
pauls painting
illinois
where can i get the hiem joint part for the pedal? need one asap as the slave cyl rod is craked thanks
typ4
Newberg,OR
Just go to a napa and get in there parts and accessories book and they have heim joints in several sizes, about8 bucks or so, I cut my loop off and threaded the rod 3/8ths fine and it works awesome
pauls painting
illinois
napa said they dont carry them . that is the first place i went and he didnt know what it was hiem joint? tried az no luck .
Mr_Roboto
Elyria, near Cleveland Ohio
Heim (brand) joints are aircraft bearings, which are also used in some other applications. They are not a truly automotive part. Their technical name is a "spherical rod end bearing".
Any bearing supplier will know what you are looking for and be able to source them. Popular manufacturers are Heim and Torrington.
I spent 3 years managing a bearing warehouse.
typ4
Newberg,OR
Napa number for 3/8 female and 3/8 ball hole- 732-1129
balkamp number
hope it helps
russ
