Check out this Scary Lift:
dakotajeep
Patrolling
TN/ND
So there is absolutely no leafs or springs in the suspension? Crazy!!!
LCAM-01XA
my very own hell
Darrin, did you read the FTE thread on that truck? The lift ain't actually as bad as ya'll may think, granted he screwed up big time on the U-bolts and steering linkage, but his lift blocks setup with the trailing arms can be made to work quite decent after a few hours of welding fun ;)
LCAM-01XA
my very own hell
Front still has the factory leafs, rear I have no idea as it's no clearly seen in any of the pics but it looks like he relocated the spring hangers away from the frame.
88beast
pa
sweet truck bad lift that must ride worse than a tank
wpfd571
Kalamazoo, Mi
Stuff like that is why more states need to do vehicle inspections, at 55 when that crap lets loose its gonna kill somebody. And for 8 grand he better throw in the cowboy hat ;Sweet
Brimmstone
I've done hundreds of lift kits and fixed hundreds more someone cobbled together and I've never seen one that crappy
sootman73
Wauseon, OH
wow i wouldn't trust that anywhere! look at all the steering linkages. especially the tie rod and see the bracket at the pumpkin? what the ph..................? and you think the axle is warped some seeing how much weld is at the drivers side bracket? or whatever you would call that....
i'll give him a thousand for it..... LOL
1994Diesel
Constantly thinking
Central coast, CA
HAHA! That is terrible...
Its not as bad as i though it was, at first i though those were cinder blocks! I was thinking, wth, how are those supporting it.
Is it me or does that cross bar look uneven, and it looks like one leaf has more of a positive arch than the other.
So, the long the U bolts= less strength? right
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
:rotflmao :rotflmao :rotflmao :rotflmao
Bet the first time it was off roaded hard, it would twist the drive shafts and break the u joints due to the drive shaft and pinon angles. :eek:
They say *** sells, but in this case I'm not feelin' it. ;Really
LOL
Oh, and the truck is a farce. That suspension arrangement must get real interesting on uneven terrain. I can't believe they didn't even try adding some leaves to it so the "extension sub-frame" wouldn't have to be so tall. Some things look really cool until you get under the covers. Truth can be ugly.
memphisrain
Calumet, MI
You know the guy is an idiot when he paid $500 a piece for Ground Hawgs....
Even the girl knows what a P.O.S. that thing is, you can tell by the look on her face.
However, I will see your crappy front lift with blocks and stock leaf springs, and raise you a lift with an entire subframe:
more piktures: Here
mR
argve
Resident Fruitcake
Gwynneville, Indiana
I personally think that the lift was thought out, now it could be better because he is rely'n on the ubolts to hold it together. I think that if you added a link on each side from the axle it's self to the frame that would capture the axle tube that it would ok (as in not shoot the axle out from under the truck). I would like to see some taller springs on it so that you can actually get some axle articulation out of it, right now as it sets you won't get much at all. So it's as it sets a pavement princess in my opinion. Can't really see the rear set up but I think with just a little work on the front it could be a pretty good safe deal.
