chillman88
It was a PBR night! Any thoughts what I screwed up???
There's your problem, quit using cheap parts
Thanks, I'll do it!Might check for voltage at the b+ terminal on the alternator to see if there is a voltage drop there, then check for voltage at the spliced wire. If you have correct voltage in both spots it's likely a bad alternator
