greasemonky
I see alot of guys using 3 part filters 20micron and then 1 micron etc,etc. For filtering then WMO,WVO or what ever alternative fuel they plan to run. My Question is which is more cost effective and easy to use plus which is the better filtering setup??
I will start be saying that I have a Centrifuge setup for under $150. It can be purchased through PABIODIESEL. They have many sizes to chose from. So far it works great and filters some amazing crud from the WMO that I put through it. O just clean it out and go again. So besides the electric cost of the motor to pump the oil and the little coleman camp stove to heat the oil it's a one time investment.
Right now with my Brother and I both having IDI's running 50/50 WMO blend we Filter roughly 15 gallons a week. I usually filter Batches 15gal. at a time, It's quicker to heat some amounts, and run the centrifuge about 3 hours total per batch. My centrifuge is a 60gph unit, so 15gallons is filtered 4 times an hours. 3 hrs 15gallons is filtered 12 times. I am confident that my WMO is probably cleaner than the diesel at the pump.
How often does the bags and hard case filters last. How much per hr filtering before they stop up and need changing? I'd would like to compare Pros and Cons to both setups. Thanks for any input on these matters.
