I need to inject a second view into this matter of "warranties"
First, are you using the product for it's intended purpose?
This product was designed to pump diesel fuel to a refrigeration unit.
Are you feeding it diesel fuel or are you feeding it a self created cocktail?
Are you pumping it into a refrigeration unit?
Only you can honestly answer this question.
IMHO this is the reason why this country is in the trouble it is in.
Nobody wants to take personal responsibility for their actions.
Case in point.
We are using these pumps inconsistent with what they are designed for and we are also feeding it a cocktail that is not consistent in purity or quality.
How can we hold the manufacturer responsible for the product if we're using it outside for what they originally sold it for?
If you want to push the envelope of the norm, do be prepared to accept the fact that things will go wrong.
I've been warning about the use of mixes greater than 50% wwo(waste whatever oil) to diesel fuel for a few years now. There is a danger with causing serious damage to your motor. You can choose to listen or not. But you also need to be prepared to face the consequences of when things go wrong and not think that there is a safety net to catch you.
good luck with the "warranty"
i know you weren't going that route, I was referencing to the talk about holding the mfg to the warranty on the pump.im not going to f-@# with the warranty and i know that i was pushing the limit of the pump but dont worry ill figure out a better way to feed my engine
a mechanical lift pump will outperform a electric when mounted in the engine compartment area. Electric pumps push better than pulling, whereas mechanical pumps will pull better but will not push as much volume. that is why you see the electric pumps are mounted right at the tank on most competition setups. We can't do that on our trucks due to the feul switching valve. they can't take pressure going through them but can take vacuum. that is why you see most electric pumps mounted just foward of the valve.i wonder if the stock mechanical pump will do better than an electric lift pump or what do you guys think about that
semantics.....wiseguy.no kidding
ill bet when mounted to the engine block it works even better
just givin you a hard time
