Andrew M. Frankli
Love my '93 NA 7.3 CC. HATE the E4OD it's stuck with. Had recurring stalk OD on/off flash. Code 62 ("Trans slip") which someone on this forum informed me was TCC slip. Anyway, I knew the trans fluid was a little over-full since I changed it and the filter several months ago... thought nothing of it since it was only 1 qt too high and I've got a couple of nuisance leaks @ trans cooler & lines. Just for fun I siphoned out the extra quart and didn't think much of it and lo and behold! For the past 2 weeks the light has not come back on! Still shifts like muck, but has not triggered limp-home and flashing light like it had regularly in the past.
By the way, the light never came on before I flushed and overfilled the trans back in Oct., a month after I got the truck.
Has anyone heard of a slight overfill on E4OD triggering slip codes???? Thanks. Sincerely, Andy.
. Then I found bad bearings in drivers side front. Now friggin' snow all over the place. grrrrrr. The Baumann TCS has so many variables that YOU can set and lotsa trick goodie functions, it is definately worth the money. Ford had to make the OEM computer to fit soo many dirrerent driving charastics it can't possibly fit everyone. But the TCS can be set for how YOU want he trans to shift, and WHEN you want it to shift. Shift it manually by pushing a button, 1st, 2nd, 3rd, 4th, up or down TC locked in whatever gear YOU want....2 sets of tables, one for around town the other for towing/racing/whatever. You can change line pressure for FIRM/HARD/Cadillac shifts. What more could you ask for? It's perfect.
