FoolhardyIDI
So taking the family for a fishing and camping trip in November. It will be about 20-30 degrees at night time and in the 60s during the day. Is there anything I should check over or be aware of for this trip. It will only be 400 miles round trip. I don't know very much about the truck as I bought it 3 months ago now.
I did change out all the coolant with Final Charge. Changed out the engine oil & filter with 15w40 Rotella. Changed out the trans fluid & filter with Kendall Classic ATF. Changed the rear diff gear oil. Lubed up all the front steering zerk fittings. The power steeing pump was leaking very bad so changed that out, and while I was in there I changed out the steering gear box, It had a ton of play in it. The front calipers were bad, got new ones and installed them. I will be tearing into the rear brakes this week to see if they are ok.
Is there anything else that I should be looking at??? All help is appreciated.
