Built 7.3 Idi Turbo fuel pump
FordGuy100
Silverton, OR
Nope, just wastegate unhooked. To be fair I couldn't tell you what it is above 15 psi since my boost gauge is 0-15. But considering where the needle lands I'd wager upper teens low 20's.
FordGuy100
Silverton, OR
Yes. Pump is maxed. Timing unknown but I did advance it a dimes width almost 10 years ago and doesn't sound advanced.
pelky350
Springfield, OR
I run 15+ also but not all that often for years now with no blown gaskets yet, but not really stock anymore. R and d 90cc, stage 1’s, carter 4070, “factory” turbo with banks compressor housing and 60-1 mod with ats 093 hotside. 10psi is just about instant even with intercooler
Justin1574
Mississippi
You didn't have to re-stud the heads on it? My truck is all stock. I just really don't want to over-boost and grenade the motor
Macrobb
North Idaho
You won't grenade the motor. Worst case, you'll blow the head gaskets and have them start to leak combustion gasses into the coolant.
Clb
Another old truck
nannyfornia
Yep
We should hook up.
You get the flatty ready for spring?
Yep
We should hook up.
1 is done
2 needs intake gaskets to cure a very minor oil leak.
3 is underway...gonna day cruise this summer!
lets go tubing!
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
Ok snow run is in the books...
time fer me to catch up some...
brians rigs (in my recognition) do not leak,
my ford guy bailed on the run...
i will make a call on heads.
@IDIoit Schweett
IDIBronco86
