Bricknose vs OBS master cylinder differences
Macrobb
North Idaho
Got a cost-saving question here - Looking at swapping out the MC+slave on a Bricknose truck. On Rockauto, they have one kit for $120. This guy
However, I have more choices for an OBS, including one set for $74.
Now, from what I know, the slave is going to be the same, the hose might be a little different(but similar routing). The master, however, seems to be slightly different - holes instead of studs. But is that the /only/ difference?
Any thoughts? If it is just the holes vs studs issue, I'll go with the cheaper one and make it work. Otherwise, I may have to use a different solution.
Nope, just use the correct year. If you put a obs master in a brick, it'll sit cockeyed. BTDT. It's really not too big of a deal, but not ideal either.
Although, you can buy pre-bled assemblies for the obs. Also for the obs (maybe others) you can get a steel, braided ss line. (At least my psd came with one)
Someone actually found a metal slave too.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
Metal slave is made by Perfection the clutch company. I was researching one for my OBS PSD. Didn’t check brick, has new already. Rock Auto read the info tab on each. The metal set is what your rock auto link goes to. Sitting here in the dark in good ole Calif.
Garbage_Mechan
Garbage Mechanic
Looking at both my 91 and 96 right now it is hard to tell if the mount is an issue. Are the bore sizes the same? I do know there is a difference in the pushrod because the trick I used to convert to a Heim joint on the 91 wouldn’t work on the 96 due to smaller diameter pushrod. Made a different plan work but eliminated the factory clutch start switch.
One of the new ones I installed one time bolted on at Saturday funny angle but the master cylinder turned and it's Mount straight up I don't remember what brand it was.
For what it's worth I have a steel braided line kit for the clutch assembly also.
Selahdoor
Index Wa
A twofer today!!! ;Poke;Sweet:rotflmao
The flames don't produce any light? :rotflmao
What angle is saturday supposed to be? :rotflmao
ttman4
Last Nite's Dream..
you know I can't get my speech-to-text to do normal things but it'll sure pick up words off the TV clear as a bell.
Yes! Yes! yes! I've had one these SUPER SMART phones for 2+ yrs & Siri still can't decipher my stupid transplanted Texan accent!! But she sure can hear the TV, hear the wife hollering at me, hear everybody else! My son says that they can be set to hear French, Spanish, Chinese, Gibberish, all foreign languages. How come it can't hear me??
I learned to proof read EVERY text before I hit send. Send a nice, pleasant, complimentary text to someone & ck it later......figure out that it went thru as: "you low life f@*%@# scummy....."
(Text the preacher & wind up thru the hot blazing gates of Hell..... LOL LOL
Because you've been with her for a while now. She ignores us just like a real woman after a while.:joker: Seriously though, I was working for a guy who had a 2015 Chevy Duramax. He always tried to use the voice activated GPS in it. By the time he finally went through all the BS (including breaking the address down into individual parts like state, city, street, number) we'd usually almost be there. If I had to drive it, I'd just punch it all in by hand before I left. It always worked the first time. I say take that voice activated crap and throw it all away!
m2rtin
Staff online
