Brand new to me (just as of this mornin) '90 F350!!!
cbarm
Medicine Hat, AB
OK guys, here it is!! Massive tanks on this thing. I bet I could drive about 1500 miles + with this before needin fuel!
X-NRCan_IDI
Ottawa, ON
very nice truck! I've been looking for a pic with that kind of two tone paint job. Looks good! ;Sweet
cbarm
Medicine Hat, AB
Thanks! Actually this truck has a really crappy paint job on it. The factory color was the navy blue from what I can tell and someone did a backyard paintjob on the white stripe. I am considering getting the body work done on this and then repainting it to factory color...add some chrome trim n alcoa's and thsi would be one sharp rig...
cbarm
Medicine Hat, AB
Here is the 2 of em side by side...the summer and winter trucks!
cbarm
Medicine Hat, AB
Now for a couple of issues I have found. The rear doors (both) dont open. I took the inside panel off and the door handle is moving the rod to the latch, but nothing is happening. What can I do next? Also, the E brake pedal is all the way up and is jammed to the point that its bent and I am not sure how to unlock it...the headlights work fine, but when I switch it to highbeam the headlights go really dim like there is a short somewhere, but the rest of the lights stay normal...any ideas guys??
Keeway
ALL MOTOR!
Keewaydin, PA
Well I can offer my advice on the headlight problem. Idk it could be somethin else but mine did the same thing as yours is doing and it ended up being the dimmer switch on the floor. And for the doors and e brake id tear them apart and clean all parts. And get them free'd up.
91F350idi
Cody S.
Bucksnort, TN
Now that i think about it though, I guess your dimmer is on the column with that newer dash? So if thats the case then maybe not the same as when my floor dimmer switch was acting up:dunno Nice truck btw, Im kinda jeolous;Sweet
cbarm
Medicine Hat, AB
Yea, they took the dimmer off the floor and its now on the signal light arm on the column...and there is no separate fuse for the headlights on this truck grr
War Wagon
Terry, MT
Check out that orange boot that goes into the turbo. It is notorious for tearing. There is an updated replacement from Ford (black boot). Also, check the air box. Sometimes the studs will break out of the bottom or the nuts on top may strip out if they are still the plastic ones.
Coyote_Red
Chelsea, Mi
The front axle alone is around 800-1000 dollars. You sir currently have my dream truck that I am trying to build right now.
91F350idi
Cody S.
Bucksnort, TN
I would love to have a pair of new dually fenders on hand for that dreaded day when the good ones i worked so hard to get, get damaged mysteriously when im in walmartLOL
tke395
