Brakes
JRJ04
Sugar Land, TX
Hey guys, I need to replace my brakes. any reccomendations as to what kind of pads to use? I currently use wagner heavy duty pads but they are only lasting about a year. what would be some reasonably priced pads that would be better than motorcraft or what i have now?
JRJ04
Sugar Land, TX
ive got 97k, this will be the 3rd set ive put on, and id say its an even mix between city and highway.
something else i thought of too...everytime i replace the brakes they pull real hard to the right until one of the pads wears down a bit. then its even. i've had the calipers replaced once before. any idea why it does that?
Double-S-Diesel
parts seller
derry pa
33k a set isnt bad
on some of the work trucks I work on they get 15k
as for the pull, how are the sliders, Ive had lots of them froze/corroded.
JRJ04
Sugar Land, TX
if that were the problem, would that be as expensive of a job as replacing the calipers?
Double-S-Diesel
parts seller
derry pa
sometimes they can be freed, and cleaned up. other times theyare gaulded so bad that the braket need replaced.
JRJ04
Sugar Land, TX
Well, I'll definately have to look into that. So as far as what type of pads to use. Any suggestions?
pwillis
