Saskredneck
Since I bought my 86 2wd brakes have been sketchy at best, not a huge problem I go into the city once in a blue moon and 99% of driving is on back roads or highway to get to work. Brakes do work but the pedal is almost rock hard, if you ease into it and don't fully release or pump them they work good but slam em down or pump them on ice to slow down things can be sketchy. Pads are good all around and nothing is leaking, I'm starting to lean toward a failing vacuum pump, but my 4x4 doesn't have the vacuum pump hooked up and brakes work great? Every master I've had fail brakes always went soft so don't think that's the issue. Should I replace pump with stock one or upgrade to a better system? Truck does a lot of heavy hauling and have some heavy loads lined up to bring stuff home in the summer, sick of having to rely on trailer brakes without proper working truck brakes.
