marmot
On the bench
Hey Yall, I have really been enjoying all the knowledge I have gleaned from your forums so I joined up! The information I gathered inspired me to buy an IDI.
Today I took possession of a 1993 f250 XLT extracab turbodiesel (7.3 idi with factory turbo) 5spd in red with gray stripe, it was cheap and for a good reason. The guy I bought it from said a lady had driven it up to his shop last january and said "It started this morning and then died, after that I had to crank it forever to get it started" She then requested a new IP, glow system, filters and injectors. The guy called her with a bill update and she said forget it you can keep it So they stopped right then and it sat with the new glow system and injectors installed and ip lines half installed for a year. The lady who owned it was clearly a sheep herder and somewhat short of a 6pack. I pulled 150 gallons of trash out of the front of the truck alone! mostly paper thankfully. Some mouse droppings from the year it sat in the yard but no real damage as they had plenty of trash to live amongst. The trash although nasty and annoying to remove seems to have had a positive effect, it protected the carpets and seats really well. The back seat was down and covered by a mat and blankets/ trash and is perfect! Passenger bucket is fairly clean, Drivers seat is dirty and has a small tear.
The guy selling it was very motivated so I low balled him at less than half the asking price and got it for 500$
The good: coolant and oil look good and the turbo looks clean, 170kish (could not verify with bad batteries) no apparent oil leaks and clutch/tranny seems ok paint and clear coat are good New IP, injectors and glow plugs/relay.
The Bad MOUSE POOP and sheep dog hair in the carpet, broken welds on back of drivers bed side, no tailgate, a shattered drivers extra cab window(still watertight), and a couple big dents that look very pullable.
I am really excited to get it fired! I have 4 diesel cars and trucks including a 99psd; Um make that 5 does that qualify me as a compression ignition addict? I have always wanted an idi turbo so I hope it runs. When the weather warms up from -20s I will check the install of the pump and replace the injector install kit, and fuel lines. I have a facet pump on order for it at napa.
The only part (so far) I am missing is the plate on the ip cover that hides the ip bolts...anyone happen to have one lying about or a ford part #
