By the sounds of the replies you guys are throwin out numbers and suggestions for a STOCK turbo.he is runnin the BDP dominator turbo.i dont believe you can swap the housing on it.i bet if he called bdp about it ryan would say the same things im saying.larger turbo requires more fuel.i bet when he does the injectors he will be in the 40+psi range and will be askin about head studs next
