NA= 19.44:1
7psi boost= 28.7:1
10 psi boost= 32.66:1
15 psi boost= 39.28:1
Just for grins heres a comparison to my mild elevation of 1mile above sea level
NA = 18.40 :1
7 psi boost = 27.16 :1
10 psi boost = 30.92 :1 (current wastegate setting)
15 psi boost = 37.18 :1 (most likley wastegate setting post intercooler)
20 psi boost = 43.43 :1
And with that I agree that if your bolting on a turbo do headstuds at the same time, its a cheap guarntee to never have to worry about boost pressure (no one has blown a headgasket with properly installed studs) however to play devils advocate the "safe" boost level without studs is still debated, some have blown at 7psi others are running 20 with no problems (Ill also admit I dont have studs currently but I bought the truck post turbo install and pretty sure the turbo is pre 2000 install)
