As mentioned thats a Valve Cover issue there.
When you remove the valve cover, both gasket surfaces must be cleaner than surgically clean! So clean the head, then do it again and again each time with fresh clean rag not dipping it in oil etc. Get the heads gasket surface cleaner than clean, and do the same for the tin valve cover too.
If there is any residual oil, and I mean any, then oil will eventually wick out there.
IIRC bout 72 INCH LBS torque, hope this helps.
Al
Yessir. I've read several of your praises of the Elephant Snot. I'm going to track some down. Does it resist diesel? Oil? Heat? Copy on the torques specs. I have read several thread posters from all over the web stating 6 ft lbs as well. Thanks.
I'm not a fan of RTV however it can work, I'm a fan of the Elephant Snot as I call it, Permatex Aviation Form a Gasket is the real name, apply thin coat to head and to valve cover install the gasket the valve cover tighten carefully to torque and be done.
