Blower motor
kbenz
kannapolis, NC
Maybe the system is slightly overcharged? Maybe it's just so good that you can't run it full blast all the time?
I turned it off and opened windows for last 30 minutes of my drive then tried again and still sucked.
DougBoy66
Cass County Missouri
When I first start up it takes a bit for it to start blowing good too
Mine is that way, check the defrost vent for flow. Mine seems to take a bit to come out the dash vent until the vacuum builds up but it is blowing out the defrost until then. I need to replace that white colored vacuum hose that goes to the blend door by the firewall
kbenz
kannapolis, NC
Might be a couple weeks before I drive it enough to act up. But I did fix the blower motor connector. That was one of them run what you brung things and I’ll fix it right this weekend things 2 years ago
kbenz
kannapolis, NC
I’ll Check that next time I drive it
jim x 3
1988 F-350 DRW
northern california
KB:
Listen to Greenie, your evaporator is freezing up.
You say that after AC is on for an hour, the accumulator (round thingy) and lines freeze (with frozen condensate) and your air flow dies out. Therefore your evaporator is also freezing up.
You can check the blower by running it on HI for an hour without AC. Your air flow won't die out. [Don't do this without the engine running, you'll run down your battery - the blower takes a good bit of power].
Your evaporator is a radiator (in reverse) in the air ducting downstream of the blower - it gets cold when the liquid refrigerant sent to it EVAPORATES. When it gets cold, it cools off the air going thru it. If it gets too cold, it freezes water out of your air stream, which plugs up the evaporator air flow (freezing it up). Then your air flow dies out. When you shut off AC, the ice thaws and drips out of a tube below the cab. If you shut off the truck or run without AC your AC function will return to normal when all of the ice melts away.
Your evaporator is getting too cold.
So you need to figure out why this is happening.
Regards,
Jim x 3
Black dawg
sw mt
KB:
Regards,
maybe my reading comprehension sucks right now, but I dont think we have been given good enough info to decide anything for sure.......
Danielle
No, it's not finished
Dirty Jersey
Also check for rats! My truck sits a lot and I get nests everywhere. This year was a nest surrounding my blower motor resistor, but I believe it was rubbing on fan and fan would get too hot and kind of stop/slow to nothing after 20 min
Its also pretty easy to take fan out of HVAC box and run it where you can see it, so you can monitor if that connector gets super toasty, or you can see rodent nests in the box, or smell resistor or fan motor
Here's some rats, both welcome and unwelcome rats
jim x 3
1988 F-350 DRW
northern california
Agreed, my proposal is only a hypothesis. Its up to KB to determine if it holds water. It would be easy enuf to check: a blower that doesn't die out without AC and an iced-up evaporator can be readily seen if the blower assembly is removed from the duct.
kbenz
kannapolis, NC
That's exactly what it was. That vacuum plunger under the dash is slow. Then after an hour or so it's probably switching back. I finally drove it today but not long enough to have it mess up after driving a while
ihc1470
Idaho
Does the air flow switch when it acts up? You could put a gauge on the system and see what you have or connect a hand vacuum pump to the supply hose of the HVAC system and see if it holds vacuum.
