I knew I should have pulled the whole s**t in the first place.
I've got everything off the top of the engine down to the block. The only things still attached are the front cover, water pump, and timing gear cover. Can anyone tell me how much the engine weighs now, without all the other stuff attached to it? I need to figure out what equipment I will need to pull it.
Thanks.
Rob
I've got everything off the top of the engine down to the block. The only things still attached are the front cover, water pump, and timing gear cover. Can anyone tell me how much the engine weighs now, without all the other stuff attached to it? I need to figure out what equipment I will need to pull it.Thanks.
Rob
