Just get a travellers plug in adapter that will handle the wattage of the heater. Most of the ones designed for high output hairdriers will do the trick, either that or put a 240 block heater in the thing. If the truck was sold there originally, then the block heater in teh thing would be a 240v block heater and all you need is a new plug that you can pickup at a local dealer or parts supplier.
I've has a number of European cars that came directly from Europe with 240v block heaters in them, they look just like their 110v counterparts in appearance, only difference is the plug.
I have one car that came from Finland and that sucker was WIRED! it had a 240v block heater, 240v wiring running into the passenger compartment to run whatever other heaters and bloweres, and it had an Eberspacher diesel fired block heater for when it was someplace where it couldn't plug in.
