Battery Relocation
ddec4me
Nampa Idaho
Thats why I asked. I have heard conflicting stories. Some say ramair is the way to go, and some say there is too much disturbance at the core support and you actually get less air. I have been doing lots of research however and have decided to go with the ramair. I already have a hole in the bottom of my filter box so I dont worry about water getting past the filter. I plan to do the project tomorrow. Thanks for the ideas and I will share mine with pics when I get done.
dyoung14
Is getting worn out
spencer,tn
i think you will be very happy with it if you do it, you get alot of cold air ramed straight to the turbo, instead of hot under the hood air.
frank-id
Twin Falls, Id.
Batteries relocation
I moved da batteries to behind the cab on the frame.
Easy to service and connect jumper cables to aid others. Frank
dyoung14
Is getting worn out
spencer,tn
thats something like the older trucks use to have, the were below the floor bord nice job
