Axle ID
oregon96psd
Kuna, ID
Originally there was a metal tag on one of the diff cover bolt's that had the ratio on it.
If the original tag is missing off the diff covers, then the build code on the axle or pull the cover and read the numbers on ring gear.
JM2CW
jaluhn83
Upper Marlboro, MD
Or have someone hold one wheel, turn the other and count yoke turns - you just have to multiply by 2 then to get the actual ratio.
