WarNose
Thanks to this sight I just learned that I have the Sterling rear end with 4.10 gears and limited slip in the rear and a Dana 60 in the front.
What weight of gear oil should I put in? I know that I'll need to put an additive for the limited slip. Since the rear is limited slip is it safe to assume that the front is also? Will I be using the same weight for both the front and the rear? Right now I don't tow anything. I may get a small camping trailer next year but nothing heavy. Occasionally I'll do a dump run. Thanks.
