ATS 088 turbo
itsacrazyasian
residentcrazyasian
boca raton, fl
Ok so i'm gonna end up buying the 093 kit from another member here as i've outgrown the 088 and i can throw a aftermarket turbo and intercool it with the hot side plumbing on the 093.
The ATS088 will come with a pyro, the turbo itself has a new factory Garrett CHRA. I bought the turbo from gonecrazyi a year ago and replaced the CHRA before install. The CHRA has less than 10K on it, light surface rust from rain but no oil leaks. There is a K&N filter for the air box. It was new at install. The y pipe was broken when i first got it and had the iron y pipe welded. Its been leak free and solid since. The section that was welded i sealed with some permatex high temp exhaust repair just to be safe but found that it just flakes off leaving the repaired section visible and leak free.
Its been on my truck with a C6 and a zf5 so i know it'll fit both.
The CHRA was 500 alone. The only thing you won't get is a CDR relocation kit or valve cover with the provisions for it. I took my front ip cover and made my own. there is a clean cdr on the air cleaner already that comes with. The downpipe ends right at the transmission crossmember.
Firm at 500 + actual shipping. Got MUCH more than that in it.
93f250idi
strokin
cadiz ky
I might be interested in it. Looking at a hypermax system
Right now that I might be trading some stuff for. You interested in any trades?
