LCAM-01XA
If yes, how smooth does she shift? For comparison purposes I present my T19, where you clutch halfway in and put a slight pressure on the shifter and she just slides out of whatever gear she's in and right into the next one, smooth as can be. On the other hand my NP435 appears to do just the opposite:
1-2 shift feels like three "bumps": a good one while pulling her out of 1st, another as she goes into what would be neutral if I let go of the stick, and she "catches" once again as she goes into 2nd.
2-3 is actually pretty decent, every once in a while there's slight "catch" as she enters 3rd.
3-4 also feels bumpy, but not anywhere near as bad as the 1-2 shift, just a single bump as she enters 4th.
Additionally, the whole revv her to the moon then shift simply doesn't happen with this one, I can do a 2-3 at over 3000 but 1-2 and 3-4 are pretty much maxed out at 2500rpms, any higher than that in the lower gear and she will fight me going into the higher gear and requires rev-matching with the throttle (as opposed to the T19 where by the time the engine speed drops on its own past the "float" point she's already in the next gear). Still goes in gear fine tho, never misses, I just gotta be aware of her quirks and work around them.
So I'm pretty sure my 2nd and 4th gear synchros are about done, 2nd worse than 4th. Question is, if I tear her apart and give her new synchros, how smooth will she get? Can she ever match the T19 which dang near shifts herself? Or will it be just a minor improvement over her current behavior? I'm trying to figure out if it's even worth it to pull and rebuild this thing, or just run it as is while I look for a creeper T19 to rebuild for butter-smooth action like my close-ratio T19. Personally I don't much care one way or the other, but I got a teenage girl who wants to (and should) be able to drive the truck as needed, and she just doesn't feel very comfortable with the NP435 as it is now...
Thanks!
Thanks!
