anyone ever try to make a better return line system?
SPR1NK
Stevensville, MT
Has anyone ever tried making a better return system?
Like milling some new caps out of steel and putting threaded flare fittings on them and using some homemade brakeline sections to replace the rubber lines?
Yes. A member did fab a set of caps and its in testing now. They are a one piece from aluminum done on a multi axis mill with a cnc program. I recall the signon name was AVD I think. As for remaking the entire system I feel its not needed. Our return is just a gravity feed return anyway. Not much can be improved on that. I do like the new caps idea. About all that needs to be replaced with new steel caps is the o rings and the hose.
SPR1NK
Stevensville, MT
Just the caps out of aluminum? And then still use rubber hose?
I was thinking steel caps and brake line or something to replace the hose between them just to try to make it as bulletproof(leak free) as possible
mblaney
Ottawa/Ont/Canada
hard lines like that would be a major ***** to work on! I think just using quality hose and greasing your injectors before installing the caps makes them reliable enough. I guess the return lines should be considered a regular maintenance item...
You will probably only have issues with the existing return line systems if:
-you are always disturbing them playing with injectors
- the caps were installed without sufficient lubrication and the o-rings are hurt
- the system is so old that it is now due for maintenance
The rubber lines do catch hell with the engine heat... other than that I doubt that better quality caps would make much difference. I always use Viton o-rings on mine (P/N 111).
SPR1NK
Stevensville, MT
My main thought was more just for not having to buy new caps and stuff, if it made it a little harder to work on that wouldn't really hurt my feelings any
Black dawg
sw mt
The problem that I see with hardline between the return caps is that lengths would have to be perfect, or it would push or pull on the cap, possibly causing the o rings to leak.
A different injector body (like the 12v cummins) with hardline bolted directly to it would be cool though.
SPR1NK
Stevensville, MT
That would definitely be a problem, that's why it's more of a conceptual idea than an actual, I'm gunna make it tomorrow type thing, and also why I asked cuz I was just curious on the feasibility of the idea
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I've always been under the impression that most of the time you get a leak on the return line system, it's an O-ring on the injector itself. So, I don't think there's much that can be really done to improve the system short of redesigned injectors.
I have to admit, I always wondered why IH and Stanadyne went with this design on the IDI. The M-B and VW diesels (Bosch fuel systems), and for that matter the 6.2L/6.5L GM's (Stanadyne fuel systems), have hose nipples built directly into the injector, and you just daisy-chain rubber hoses between each injector...you don't even need clamps. Seems to work well; I wonder why they went with an unnecessarily complicated system on our trucks? :dunno
tke395
