Anybody know about this fitting? OEM Radiator Trans Cooler
SDEconVan
San Diego CA USA Earth
I'm weighing options. Seeing if the threaded fitting comes out of the Radiator or is it sweat-fitted into the cooling tank:
This is the Transmission Cooler at the bottom of the Factory Radiator. 1985 Ford 6.9L Club Wagon van.
27mm socket got the locking nut off:
Ideally, I want to connect an -6AN fitting to the Rad. So far the adapters I found still have a small I.D. of
the stock 5/16" hard line.
Thanks in advance!
Best regards,
George
89Laredo
Underemployed
Sheffield, ia
Why do you feel the need to use AN fittings?
I really don't understand this AN fad, especially the people that pay 10 bucks for a fancy colored aluminum fitting when they can get the exact same thing in steel for less than half the price (jic and an are the same 37° flare).
Looking at your second pic, that fitting looks soldered.
SDEconVan
Anyone know the thread size of the fitting coming out of the radiator?
Am I correct that they are 1/4 NPT?
chris142
SoCal
Taking that nut off usually results in a coolant leak. Thats not a factory Radiator. Those are soldered, many aftermarket ones are just put on like yours. The threads should be 1/4 pipe.
SDEconVan
Thanks chris142,
thought it was 1/4 pipe. Too bad for me, it is a limiting factor to trying to have 3/8" trans cooler hard lines:(
(I still will have 3/8" lines but just noting the journals inside the E4OD are smaller, and now I know the Radiator has smaller
holes too.)
Radiator is original on my van. That outer ring nut is stamped steel, was finger-tight. I see brazing or solder as you mentioned.
Best regards,
George
AN fittings are really nice! i mean the REAL ARMY/NAVY fittings. not those cheezie billet aluminum shiny "im faster than you" fittings.
they are usually leak free and easy to swap out.
i did an entire car in that garbage once. because i was getting paid to do it.
i would never run them on my ride.
altho they are easier to flare than a double flare.
after building many vehicles, i will not run an automatic transmission without an aftermarket cooler.
it makes swapping radiators and working on the car that much easieer.
