to those of you that has adjusted the vrv, my question is when you pump up to 20lbs of pressure to the vrv and cycle the throttle 5 times is it supposed to hold the vacumn, are slowly disperce of the vacumn everytime you cycle the throttle. the way mine is when you cycle the throttle the 5 times it is completely empty. and when ever you hold it at wot, with 20 lbs of vacumn and the 1/2 spacer installed you can turn it either direction and can never get 13 lbs of vacumn. sounds like the vrv is toast are im doing it wrong. any thoughts would be nice and remember be nice. lol
