plumbtuf
Hey guys, thanks for info on truck .I will install lift pump and return lines? this weekend.In the meantime the truck is an 86 with 107k on drivetrain but original moteor died from cavatation.Has a junk yard motor in it with unknow miles on it. Truck came with original motor ( in bed) with a turbo. It is stamped Air research T4 on housing. Is this a good turbo to use? There is a turbo/injector shop in farmington NM that I could have it inspected at but just wondering if something like this is worth rebuilding or not. Also water seperator on truck is bypassed, do I need to have this hooked up or not
